Here is a bunch of info I tossed together from earlier posts and from other sites:
DISCLAIMER - I could be wrong about any or all of this information.
Some of the information posted is still speculation.
Summary of information currently available
2001 Lexus IS300 model #9500
Additional information can be found at:
Lexus, Autosite, Edmunds & Carpoint
[ Note - the prices are expected to go up 1% in the fall ]
* Base MSRP $30,500 [Invoice=$26,492] (+$495 destination charge)
- OPTIONS [ListPrice/DealerInvoice]:
* CODE LS [$1705/$1364] leather/ultrasuede power_SEATS
.....(includes homelink universal garage door opener)
* CODE LP [$1805/$1444] Luxury Package
.....(like *LS package with wood trim, colored stitching, etc.)
* CODE HH [$440/$352] heated seats
* CODE SR [$1000/$800] Moon Roof (tilts & slides)
* CODE LD [$390/$312] limited slip (torsen) differential
.............. (only 33% of USA cars can have this)
* CODE AL [$400/$320] (optional) 17" polished wheels with graphite coloring.
* CODE FT [$FREE] 16" wheels with P205/55R16 all-season tires
.....(softer ride, less curb damage)
.....(better winter performance, longer tire life)
* CODE AW [$FREE] 17" wheels with P215/45R17 performance tires
......(more agressive look, better summer performance)
......(possibly Bridgestone Potenza RE040 tires)
Dealer Holdback: $610
Port Installed Options (PIO) ("ACCESORIES"):
* CODE WL [$39/$27] Wheel Locks
* CODE LM [$66/$40] Trunk Mat
* CODE GN [$38/$27] Cargo Net
* CODE GP [$417/$298] Gold Emblems
[ Your dealer may install floor mats and first aid kit ]
You can get an idea of what packages are already "pre-built" for your zipcode using the "Build Your Own Lexus" option on www.lexus.com
BODY SPECS:
* Curb weight is 3,270 lbs.
* length= 176.6" / width=67.7" / height=54.9"
* Front-Tread=58.9" / Rear=58.5"
* wheelbase=105.1"
* Ground clearance=4.9"
* weight distribution=54%front/46%rear
* turning circle=34.1 feet curb/curb
* Coefficient of drag: .29
ENGINE SPECS:
* Engine type=2JZ-GE
* Bore and Stroke=86.0x86.0mm or .39x3.39in.
* displacement=2997 ccm 182.9 cu.in.
* compression=1
BODY SPECS:
* wheelbase=105.1"
ENGINE SPECS:
* compression=1
