here is some pics of my enclosure,
its 5 cubic ft and with displacement of all braces,ports woofer and offset of ring its 4.1 cubic ft.
im tuning this at about 30hz and will play with tuning.
the ports will fire through the rear deck
i needed to use a larger size to help keep my ports shorter for the desired tuning.
i still have to sand the front and prep, also clean up the back of ring when im done reinforceing it.
note this is a two piece box since its too large to fit in the car at its full 5 cubes. also i have to mount the woofer to the box while in car since it weighs 40pounds. ill probably call my frined to help me put the box in the car with speaker. then i will mount the box then add the extension then start my amp rack.
here are some pics and i will post when im done
oh and IS300included, im gonna run three of my ms2125s in this system..
aloha
aloha
