I was wondering if the roof spoiler stays on good with just 3m double sided tape because what if its very hot and the sticky stuff melts or what if it comes loose from all the wind blowing past it and stuff
It mounts right above the rear window. Clean the paint surface wiht denatured alcohol and then use the 3m grey tape wiht red backing. I used 4 6 inch strips, like UCLA-IS300, told me too, :wink: and maybe 2 more inch long strips to fill in the gaps and it holds really tight. It is definitely enough to hold it! Just make sure you get that 3m weatherproof exterior mounting tape.
i had mine for more than a few months now.. the 3m exterior gray tape with the red backing... its sticky like crazy.. with the heat and all
Use 3M adhesion promoter on the wing and roof if you are worried about it. If you plan on leaving it on you can have a body shop urethane it to your roof.
