1 - 12 of 12 Posts
I finally got the dyno graphs of my car
GTE Internals, 13 psi, 2 T3 Super 60s (One was smoking and died about a week later I think that is why my spool was so slow *edit* I checked im in full boost about 1000 rpm sooner now)
I was running crazy rich, but the A/F on the dyno was about a point lower then the one in my car. My Butt says the one in the car is accurate but I got a new sensor recently so ill recalibrate and see what that one says.
Next dyno will be with 2 new turbos(dont ask), Edit* 272 cams, and a SRT exhaust and hopefully more boost if the retarded manual boost controller will work.
Video http://www.flickr.com/photos/velio/4430155814/
goodness, you can get a few more ponies if you get out of the 10:1 AFR's at your peak torque. i like to keep mine around 11.7 ish, it'll make a pretty significant difference. you might want to decrease the resolution on your boost controller, you have what looks like the inverse of a spike, the difference is .2 psi - and i doubt you'd be able to tell any bit of difference from that but... hey
That must be an insane setup to fit twin T3 Super 60's in the IS300 engine bay!
Nice setup and nice numbers :) I am sure the spool will be better with fresh turbos
Discussion Starter · #12 · (Edited)
Its tight but not that bad.. getting the mani off takes a few hours though.. I did relocate the ABS which helps alot
1 - 12 of 12 Posts
