Hey guys!
Automotive exterior Composite material Bicycle part Font Pipe
today I modified my upper control arms. i did NOT shorten them in order to get more camber, i wanted more CASTER.
I am pretty happy with the angle i got with my steel knuckles i made before:
Automotive tire Tool Bumper Automotive exterior Bicycle part
BUT, with only 5 degrees of caster the steering wheel just wont return to center properly.
I did NOT want to buy adjustable caster arms, because:
-they move your wheel forward
-the IS's lower control arm simply is not designed for it. you have a RIGID connection bewteen the LCA and the caster arm.
simply making the caster arm longer puts a lot of stress to the caster arm and LCA bushings as you are forcing the pivot points away from each other.
this is why i wanted to modify my upper control arms.
what you need is a welder and some scrap metal.
start with spot welding your pivot points to a tube. they have to stay at the exact same point relative to eachother.
Train Automotive tire Motor vehicle Bumper Automotive exterior
now you have to find a piece of scrap metal which is laying in your backyard for way too long. you have to weld it to the tube so that you have a reference point where the ball joint originally was.
Automotive tire Automotive exterior Bumper Electrical wiring Gas
mark where the center of your ball joint is.
Automotive tire Tire Wood Motor vehicle Bumper
now you can cut off the UCA from the pivot points.
Train Automotive tire Motor vehicle Gas Automotive wheel system
now it depends on how much caster you want. i have about 5 degrees and want to have 9. i did the math and my ball joint has to move 25mm backwards to achieve my goal.
Tire Ruler Automotive tire Office ruler Wood
now we need to shorten the rear arm, otherwise our ball joint would go outwards by 10mm:
Automotive tire Wood Font Gas Audio equipment
add a piece of tube to the front arm. in my case in order to move the ball joint 25mm back, i had to:
-shorten rear arm by 10mm
-add 20mm tube to front arm
Motor vehicle Wood Vise Gas Bicycle part
Bicycle part Bumper Automotive exterior Tool Electric blue
see next post.
Discussion Starter · #2 ·
now get your old ball joint out when youre already here.
clean everything for a re-paint. dont get embarrassed by your friends.
Silver Nickel Jewellery Metal Circle
paint and install new ball joint
Automotive tire Motor vehicle Bumper Automotive exterior Electrical wiring
now take that massaging hammer with you and give your lex a good time:
Automotive tire Hood Automotive lighting Motor vehicle Tread
Automotive tire Hood Automotive lighting Motor vehicle Automotive design
Footwear Shoe Hood Automotive tire Sports equipment
after massaging dont forget to put your protection on ;)
youre done! you have gained some caster with 0$ paid, assuming you have a scrapyard behind your house and a welder in your garage.
and most important, your wheel stays where it is and no stress on the lower bushings!
whole job took me about 4-5 hours.
enjoy 馃嵒
This is what I had a buddy of mine do for extra camber on my IS300. He only cut off 10mm and it's been a while but he might have added castor as well. I had a spare set of UCA's from a junkyard car that appeared be true so I modified them. I then added new balljoints and Superpro bushings.
