Has anyone changed the turn signals without removing the front bumper and headlight? Is there an easy wasy like just removing the harness? I know there has to be a sticky or tutorial on it but I can't seem to find after like an hour of searching can anyone help me with this one? I've been trying to figure out how to do it for months and I live in New york so i'm trying to get it done before it realy gets cold. Please help!!!
'03 Intensa Blue Pearl
5 speed
H & R lowering springs(1.5 inch drop all around)
SRT Intake w/ ECU
Teck grounding kits(Blue)
more yet to be installed
TURBO.......The Final Frontier
Turn signal bulbs are bitch to change...
I think the easiest way is through fender wall..........(I'm not 100% sure..)
almost same way as clear corers in the bumper, but it's slightly higher...
so move the fender wall by the wheels, and reach in...
There are TWO bulbs each side... so total of 4....
Threadlocker
unless you have really small hands or double jointed fingers, it will be hard as hell to go through the fender well or get to the bulbs without removing the bumper and loosening the headlamp assemblies...
it may be possible to loosen some of the other junk that is in your way and reaching through the engine bay, but i'm not sure..
the easiest way (though with the most work) is by removing the front bumper...
