1 - 8 of 8 Posts
I have a 2001 lexus is300 bone stock, I am set on buying the cheapest turbo kit and eventually replacing it for a better, non chinese, turbo. So I needed to know what else would I need to buy with it? I was told injectors and fuel pump, but what size injectors, was also told ecu, but what ecu would get the job done? Any help is greatly appreciated, thank you....
I just turbo'd my car last year and the 1400 cxracing kit just scratches the surface. You need fuel pumps, fuel hangar, fuel lines, gauges, computer, wiring, clutch components, eventually engine, tuner, dyno, brakes. I am well over 10k with full engine build since i spun bearings at 8 psi. GOOD LUCK nothing is cheap with the IS300 , Lol
1 - 8 of 8 Posts
