1 - 8 of 8 Posts
Hey all, after driving the turbo iz around on little 3-4 hour excursions during the evacuation, I noticed the A/C doesn't blow nearly as hard after about 30 min. to an hour on the road. Even on high, it only blows like it's on low. It's still cold, but just doesn't blow like it should. Could this be related to aftermarket mods? Are any of you experiencing the same thing? Any suggestions on how to correct?
Underdrive pulleys?
Did you pull off the fwy or going lower speeds when you noticed the A/C level drop?
no, no pulleys, and I didn't pull off, I just kept on going when I noticed it. I wonder if something is about to give out.....
You should not boost with the A/C on.
didn't know that......that's good to know, but at the time I wasn't boosting either, just cruising on interstate......
other than the blower motor getting hot and overheating and slowign down i couldn't think of anything that would cause it because of boost.
I boost everyday with the a/c on too... no problems
1 - 8 of 8 Posts
