1 - 10 of 10 Posts
Anybody know of any tuners in LA,CA been looking for one for a while and haven’t been able to find any
Do you have a stand alone or piggyback ECU and no cats? If not, it is not going to happen. Unless exhaust pop is just being loud.
You could do it with cats. But they will go bad fast. Remove the cats. Your timing needs to be real low on the deceleration map and keep fuel feed the same. This will cause your popping on slowing down. Depending on your stand alone. You may be able to set an auxiliary rev limiter on a momentary switch. Basically a 2 step or launch control.
Discussion Starter #7
Can you do it ? Or know of anybody in LA that can? Also do you know what 2step or launch control to go with ? like msd or sum like that ?
Sorry, in Atlanta, Georgia. The launch control is a matter of the stand alone you have. If it will do it or you can add it. Good Luck.
1 - 10 of 10 Posts
