ok this is my 2nd go round on these..... initially I had a little help from Doug/RRT to weld up a couple steel rods with rod ends and i had him weld up some steel scrap for a firewall bracket and a brace that went behind the firewall to tie the bracket into the chassis more solidly....the firewall is so it wouldn't do crap for reinforcing the braces on its own....I tied that into my Area 51 brace & stepped back for a look....not a bad 1st attempt but the steel rods were Heavy, i kept them short to save weight...but they also looked funky & were less effective mounted slightly 'inboard' like that... also they were a bit thin to "look right" with the thick ass Area 51 Strut brace...
so i decided i'd try again....
I ended up finding some nicely sized 1 inch plus diameter carbon fiber rods online that were for another car... they came with BigAss spherical rod ends
but were JUST a little too long...they are actually really nice dry carbon/kevlar tubes with a "pretty" CF weave on top and nice long threaded alloy inserts in the ends that the spherical rod ends threadded into nicely, so..... they are perfect for what i need...
I sliced the CF tubes near the ends to get the threaded plug out & then sliced up the CF tube on the plug in a spiral so i could pull the CF back & break the glue & pull it off...
aftermaking sure the tube was square & the proper length... i glued the threaded insert/end back in the tube and threaded the Rod ends back in... BAM!!....custom shortened carbon kevlar hollow rods...
then I went to the local metal center & found some 1.14 inch square alloy tube...I sliced out part of one wall of the tube leaving a small ridge at the top & bottom and cut it down to the width i needed...
It turned out i needed to " build up" the insides of this bracket so the spherical rod ends would fit tightly, centered inside the tube and not move....note the alloy bars in the back ground...
I ended up using 1inx1/8 in. alloy bars that I cut down...these slipped right inside the 1in. internal dimensions of the bracket & fit like a glove. When inserted, the open space between them was PERFECTLY sized to allow the spherical rod end bearing to slip snugly into the opening, with NO slop....
I filed everything down cleanly & then i drilled the mounting holes thru the top and bottom of the bracket...
using those holes I marked the two alloy bars.....after drilling the bars out to match the bracket's holes, I cut the ends of all the parts at an angle to finish the basic shape of the bracket..
Not able to weld...I JB welded the two strips inside the bracket & used two of the rod ends bolted inside the parts to properly brace the inner parts & make sure they stayed put as the epoxy dried...
The holes in the BigAss rod ends are HUGE... & i wasn't planning on using hardware that large for a number of reasons... I had a nice set of spare bolts from my CF cage...male & female 'shoulder' bolts...they have a really low-profile allen head and i wanted to use them..but 1st i had to cut them down a bit...
Using these bolts meant i had to create an offset bushing inside the spherical rod end bearing for two reasons:
-1st so these would bolt solidly to the bracket with out using a bigAss (heavy) bolt that filled up the bearing internally.
-2nd so the large ass rod end would fit inside the shallow bracket, it needed to be offset outward so the thick rod end would still pivot freely for installation & adjustment. So, the hole thru the rod end had to be offset to naturally push the rod end away from the back of the bracket and allow the rod end mounting bolt holes thru the bracket & inserts to be evenly centered.
I ended up using the TRUSTY JB Cold Weld epoxy... I mixed up a bunch & poured it inside the spherical rod ends after i placed a rubber vacuum cap in them offset to one side to keep a hole open....
When the epoxy cured, I peeled out the rubber vacuum caps & the offset hole left was the exact diameter of the shoulders on my bolts for the bracket..
..when i locked these in place they would be SOLID!!
After a little filiing & sanding, here is what i ended up with...
then I tackled the measurements to attach the ends of the rods to the Area 51 brace...I moved the mount points as wide as possible on the bar this time, marked the bar and & drilled it out.
Here is a comparison of the old & new as i set up the mount points for the rods onto the bar....
I ended up grinding the heads down on some steel bolts and then drilled a dimple in the top to mount the rod ends to the strut bar & i threaded the hole in the Strut bar so the bolts threaded right into the bar directly....
Here you can see the little bushing i had ot make to use these custom lighter bolts cause they also were not as big around as the insides of the rod ends....of course.......
PS... if possible .....NEVER throw away little unique bits of metal & old extra parts from projects etc....I ALWAYS end up needing a funky ass diameter bushing or spacer or some little part shit & 8 out of10 times i am able to find SOMETHING in the pile of Misc hardware/crap i have saved to make 'it' work...
Basically after test fitting it & adjusting the rods... the thing sits & fits PERFECT & functions as well as looks MUCH better than my 1st stab at it.
All I need to finish here is the welding on the reinforcing bracket that goes inside the windshield base 'trench' on the other side of the firewall to actually provide some support here since the thin firewall provides no real support... like the Triangle brace on the Cusco rr strut bar..... only I will be making the parts needed to Correct this one & make it right...
