1 - 15 of 15 Posts
hey does anyone know where u can buy a TRD sway bar. I heard this is the best sway bar...did i hear right or is there a better one....thanx
how are area51 sway bars.... im hearing now that they are the same or better than TRD i thought TRD was the best am i wrong???
no man trd or hotchkis all the way IMO. Just get the hotchkis if you want to spend a little less money. They are stiffer than the trd too if you want that.
hey i got a price of 369 for TRD sway bars and he is waving the shipping cost can somebody tell me if this is a good price or if i should try to get him lower??They are new
hotchkis are $330.
Sounds like a pretty good deal to me. Sometimes they're hard to come by, and I think I remember seeing them for like $385 or more...
Or, if those TRD's turn out to be a little stiff, you can just trade me for my ltuned ones! :D :wink:
The hotchkis sways, i've read that they are hollow... ??
Are they? and how can they be a "tad" bit stiffer than the TRD yellow sways?
yes they are hollow. I just recieved my hotchkis sways. This might be a stupid ? but is the inner hole on the sway for the stiffer setting and the outer hole for soft?
Guru of Supercharged ISs
yes .. .the hole closest to the end is the softer setting & the hole inside that one is the harder/stiffer one....
Hollow yes but if he metallurgy is different it can be hollow & stiffer no problem .. .they could be thicker too than the solid versions of others bars....
hollow can = lighter weight & it's usually a good thing to go lighter...
... but i have no idea which set is heavier or lighter..... :wink:
go irv........
Threadlocker
hotchki's sways are heavier than TRDs, just in case anyone cares... also the front is a larger diameter than the TRD, which is part of the reason you need to change brackets..
1 - 15 of 15 Posts
