Need some help guys--went to the track last night and was dissapointed yet again with my car--last year best run was a 15.9 with a aem intake greedy exhaust and stock rims---this year best i could break out is a 16.024
srt intake
greddy exhaust
jic-fla1 coil overs
18 axis spiders
my problem is i get a decent jump of the line and the 60 foots are like 2.3 which arent bad. But the transmission is slowing me down alot---the shifts are sloppy and when i have the car to the floor the car is holding up at 6k rpm and chiilin for a couple secs and then shifting. For instence i leave the line and 1st gear is good get to about 6k were it should switch gears and the car drops to 5500 and then back to 6 again and the shifts. Does it sound like a transmission problem or are these how the stock auto trannys are suppose to shift and what should i do upgrade wise.
esc from turbo east
valve body upgrade
Any help or input would be appreciated. Thanks in advance
get a valve body upgrade from TE, and also get a trans flush at the dealer :)
If cheap is your goal an ESK will help. If not just get a valve body upgrade.
