When do u turn it on, or do you leave it on, or in the rain, or what, and do you use E*Shift more than auto or not?? help me out here
Can't Decide
BLUE OR MILL SILVER
IS300 soon for me!! Can't wait!!!!
Am I Hype-R???
i usually turn off my trac...my supra has it defaulted to off anyways, so i'm used to having it off. when it was raining and i was in heavy traffic...i left the trac on tho...just in case...
as for the e-shift...i usually use it in traffic situations sometimes...when i want to downshift instead of hitting the brakes...that's about it for me...
I changed my IS300 so the traction control defaults to off. I never use it. I enjoy having to steer to keep the car pointed in the right direction while driving in the rain.
If I ever take the car in the snow, or have the kids in the back during a heavy downpour then I would turn the traction control back on.
I tend to put the car into eShift mode whenever I drive, but I have found that it is very rare for me to use the shift buttons. Basically I leave it in eShift (enabled) mode, but with the selector at 5 which is pretty much the same things as using "D". When I bought the car I thought I would be using the shift buttons more, but they aren't as responsive as I had hopped and I find that I am getting lazy and letting the car figure out the shifting for me.
After a few scares with the traction off I said I would keep it on. If your not hot rodding your car all day I say keep it on. It will save you the aggravation of having your car smashed up!
Too much snow and ice on the ground right now... gotta keep it on.
Scott.
...yet another proud owner of a fully loaded Graphite Gray Pearl '01 IS300
I always drive in M mode. I like to have instant ability to downshift.
On dry roads in summer time I keep trac off. It's more fun this way. It doesn't hold you up in turns. On cold days and when raining/snowing I leave trac on.
In other words summer - off, winter - on.
I found trac cutting me some slack sometimes.
I was able to do a full throtle 180 (on purpose) on an icy road and trac kicked in only at the last moment. Maybe it's because of the LSD. It was fun thou.
