TRAC and ECU reprogram...
669 Views 9 Replies 6 Participants Last post by  marke1
Today I talked to the Diagnostic Specialist at my dealership and they know of both the TRAC problem and the ECU reprogramming. He said it could be from 30-60 days but I was very happy to hear that he knew of both problems and they would be covered. Hes going to contact to me soon with more detailed informantion, but all is well so far. =]
Greatest of All Time
*Black on Black o1' IS
Fully Loaded
HKS Hiper Exhaust
H&R Springs
K&N Filters
Tint
Clear Tails
1 - 10 of 10 Posts
ecu reprogram should be avail in most dealership right now. as for trac control unit, its a whole new unit replacement and should be available in about 60days.
'01 Lexus IS300
'91 Acura NSX
'95 Nissan Maxima
thats what i said lex
Fully Loaded
HKS Hiper Exhaust
H&R Springs
K&N Filters
Tint
Clear Tails
See less See more
So are both of these being covered under the warranty?
2001 IS300
Graphite Gray Pearl
[email protected]
of course.
'01 Lexus IS300
'91 Acura NSX
'95 Nissan Maxima
Sorry if this is old news, but what's the problem with trac?
What lexus will do is change the programming in the trac/abs ecu. With the updated ecu the trac system won't be so sensitive and will turn itself off sooner. FYI, the trac can sometimes engage for about a second or two without blinking the trac light in the dash. Thus, the owner interpets that as a hesitation. As of febuary, all IS300s made have the new ecu program, and the newer trac/abs ecu. Hope that clears things up.
[This message has been edited by DevilDog66 (edited March 24, 2001).]
trac will not be reprogrammed. the whole unit will be replaced.
'01 Lexus IS300
'91 Acura NSX
'95 Nissan Maxima
What lexus will do is change the programming in the trac/abs ecu. With the UPDATED ECU the trac system won't be so sensitive and will turn itself off sooner.
Sorry if I was not clear enough but that is what I meant.
See less See more
Devildog66:
I think I have noticed this happen. Sometimes it "feels" like the Trac has engaged but no flashing light. Interesting.
1 - 10 of 10 Posts
