For those who've installed the Toyo header and Y-pipe, did you end up using the hanger (the one attached to the tranny with two bolts) that the stock exhaust manifold used to bolt to? The studs that came with the Toyo header were only long enough to attach it to the Y-pipe and now the hanger just sits there against the side of the bottom of the header. I'm worried it might do damage over the long run vibrating against the header.
In case anyone is wondering, I ended up having the bracket taken off. The mechanic took a look at it and recommended that I remove it since it was vibrating against the header. He said that I should take it to a machine shop to have the bracket extended if I really wanted a bracket for the header.
