1 - 20 of 40 Posts
Im the guy who bought SupermanIS300 toyomoto s/c back in may. Well, it came the time where im actually installing it. I have Craig Paisley out of L.I. NY (supra specialist) installing it. the only thing is he needs the instruction for the black box and all wiring. everything involving the electronic install. I have an 2001 auto. Can any of my fellow netters share some wiring pictures. written instruction.?
Discussion Starter · #2 ·
no luck with lance at toyomoto. this guy does not reply to any phone call / email. Not even when i was interested in purchasing this kit new with headers and what y pipe from him. Damn, at least I could say he makes excellent products.
best way to get a hold of Lance is a guy here named Freelance. he was my liason with Lance. Toyo is pretty much a 1 man shop, with Lance being the 1 man.
PM Freelance if you can't get ahold of Lance.
give me a few mins and i'll pull up some wiring diagrams for ya.
Yeah I contacted both but still waiting for a reply. In the mean time can someone speed up the process and provide some help?
Mr. Negative
well, he's in a hurricane today or i'd call and see if i can help. Malek is the best bet most likely. and Dasgalloway
thanks seven, most important I need the wiring instruction of the electrical that comes with the SC. such as what wire form the black box gets connected to what wire in the ecu.
that i dont have. Give Toyo a hollar / email, or give malrek a PM about the blackbox wiring.
Reactions: IS_Dude
Yo bro, i just got your PM... Unfortunately the cars that i have done Toyo kits on all have been 2002+ and i do not have the diagrams for the 2001 model year...
The Toyo black box wires up JUST like an SAFC so wire it up the same... As for the J&S knock sensor, thats pretty simple too and i will start to make a wiring diagram for you the best I can off of my memory...
Sorry you are having this trouble...
Malek, i think he needs to know what color wire goes to where on the ECU. He has their black box, but the box didnt come with the wires labled.
BTW do i need to cange my spark plugs? IF so, to which ones?
smaller gap plugs for sure
not sure exactly which ones it takes
i belive you want colder plugs too, or is that only for nitrous. Eh it's foggy right now. I'll check when i get home and see i think the gap is suppossed to be like .028 -.032 at the max for boost apps otherwise the spark can get blown out.
Podiatrist
NGK3330's work ok.
And I'd run a .026 for them on a stock ignition.
for the Toyomot kit, run a .030 Gap on the spark plugs...... I have some pictures of the Toyo black box, the Toyo black box wiring diagram, but it isnt very clear... I can post that up and you can try to make the best out of what you see...
THe J&S knock sensor is VERY easy to set up, and i have pictures for that too.. Unfortunately there is no wiring diagram for that thing as i just did it from scratch on the car and i gave my documentation to Toyomoto which i have no idea what happened with it and what they did with it...
I will work on it today and post it up today the best I can....
Discussion Starter · #20 ·
thanks.
Craig ( my installer) is suggesting using the e-manage or the Haltech f10x for this setup if he cant get the wiring diagram for the black box. He said the haltech f10x with everything, wiring, sensor, ect will be about $850 plus another $500 for labor, tuning ect. Im wondering what would be my risk and if Ill be able to run more than the 300rwhp toyomoto set up. I have OBX headers and y-pipe.
Do u guys think that I could get somewhere around 350rwhp with the haltech F10x and 440cc injectors?
1 - 20 of 40 Posts
