1 - 1 of 1 Posts
GREAT JOB!! I took off my bumper today to install my turn signal bulbs and your guide was great, almost perfect instructions..3 things I think you should mention:
You need a Phillips ( is that the X one?) screwdriver, and 10 mm socket/rachet..Also on one of the last steps where it says to take off the clips for the headlights, I tried to pop it off with the screwdriver and broke one of the bottoms..if you go from under the bototm there are two little like edges you can push in so they just push right out..also it took me a while to take the actual headlight out..it started scratching it from the metal behind it when I took it off..you really have to pull hard from closer to the center..there's some thing it pops off of
Thanks again for the instructions though I'll post pics of the turn signals later :smile:
-vinny
1 - 1 of 1 Posts
