· Registered
What is the largest tire/wheel combination that you could put on an IS 300? I'm actually more concerned with the width because I know people have used 19" wheels without a problem. I don't currently own an IS 300 but I'm thinking about purchasing one in the next few months. I currently have after market wheels (17x8 Mille Miglia M11-2) on my current car (1998 Dodge Intrepid ES). They are currently fitted with Michelin Pilot XGT Z4 tires (225/55-17). I guess I have multiple questions. Is this wheel/tire combination too wide for the IS 300? Also is the diameter different? How do you figure this out? I know I got my current combination from tirerack.com because I was told it would work well on my current car.
My idea is that I would use these for the winter time. I know they aren't snow tires and 17" wheels maybe aren't the best choice but it would probably be better then the standard summer tires that come with the IS 300. Not to mention it would look much better. I also have my original 16x7 alloys and 225/60-16 Goodyears that came with my car. Could these be used on the IS 300?
Sorry for such a long message but if anyone could offer any suggestions or help it would be appreciated.
[This message has been edited by TakeFlight (edited September 27, 2000).]
· Registered
Discussion Starter · #2 ·
BTW, Even though I'm not sure how to figure out the diameter, I'm pretty sure I know that the diameter of the above mentioned tires is different then the ones that come with the IS 300. So, my biggest question will be can the 17x8 and/or 16x7 wheels mentioned above be used with the IS 300 as long as they are fitted with proper diameter tires?
Thanks
· Registered
Thanks
Don't buy at Thompson - They suck - no selection and not willing to deal.
cardinal
'01 Silver/Black
LS, LD, HH, SR, 17"
· Registered
So, do you have a recommended dealer? I know there is one close to where I work in Bryn Mawr.
Everyone else: I don't want to stray off topic in this discussion. I still would like info regarding my first two posts.
· Registered
I have been toying with the idea of replacing my 215/45ZR17s with 225/50ZR17s when my original tires wear out.
The higher profile tires would probably have the following effects:
1> Slightly worse acceleration
2> Slightly better fuel mileage
3> Slightly more comfortable ride
4> Less likely to damage wheel when parallel parking or hitting speed bumps.
5> Wheel wells looking more "stuffed" with tires
But I worry about the following:
1> Speedo would be wrong
2> ABS, EBD, or Traction control might not work right because it might be calibrated for a specific diameter of tire.
