1 - 2 of 2 Posts
What is the lowest i can lower my tire pressure to on yokahama es100 tires? Would lowering the tire pressure be better? i lowered my car and there is an uneven thread wear because the negitive camber.. Because the neg camber the tire doesnt get full grip of the ground and i was wondering if lowering the tire pressure would help the whole tire get traction on the ground?
if you lower the tire pressure, you will wear out the tires even quicker and more unevenly. What you want to do is increase the pressure so you can have more of the middle of the tire touch, and less of the inner portion.
Try 40 lbs.
1 - 2 of 2 Posts
