So for the front i have a 17inch wheel with 225/45
but in the past 2 years i been replacing tires alot
because the inside of the tires keep getting eaten up
so i was hoping to know should i drop down to a 215/45 or is there something else wrong in this set up
Yeah, you could do 215 easy. You might want to get an alignment done first.
Are you dropped, lowered?
nah the cars suspension is all stock but yea will do the aliment but was the issue cuz the tires r too wide?
Yeah, your tire specs is probably knocked way off....which is causing your tire to wear down unevenly.
