My chassis will be pretty stiff with the addition of F/R strut bar, TRD underbody brace, and L-tuned sways.
Will soon be adding Eibach springs. But given the stiffness of the chassis, the suspension will be doing a lot more work absorbing the impacts because the chassis will not flex as much due to the reinforcements.
My thinking is that a more aggressive shock will be required to damp out:
1. A stiffened(underbody Brace, strut bar, sways, Eibach springs) chassis COMPARED to:
2. A stock chassis with only Eibach springs.
Does this theory make sense? I was thinking the Tokico blues may be ok for just lowering springs, but considering the extra bracing, I may need to go more aggressive with the shocks. Any thoughts?
I'm leaning away from Bilstein because they were not designed for lowered suspensions. Are the illumina in the hard setting that different from Blues? Or should I go with Koni. I heard that quite a few Tokico owners changed their shocks for Konis. Is it worth the price difference for a heavily braced or stiffenend chassis? Thanks guys!
