21 - 40 of 115 Posts
Ok just called, headed to bank dep check, call and order my setup, but I'm going with 6 puck clutch? Hope that works to drift, I'm all motor still, just art intake,crower cams, header exhaust, what's the best ceramic, or Kevlar?
I ordered one two days ago... Can't wait to get it
It should be yes. Why do you ask?
There is a common problem where the through out bearing (TOB) will dance on the pressure plate forks in stage 2-3 setups because the IS300 slave cylinder push rod is not long enough to keep it from vibrating and there is no adjustment in the slave cylinder to compensate for this. It is quite annoying... so if the push rod for the SUPRA slave cylinder is longer (by a about an inch or so) then this would resolve the issue.
Can you meassure one to find out for sure?
Thanks
So should we get the supra slave cylinder??? Sorry guys I'm a newbie... I'm not too good with this kind of stuff, This will be my first mod
