my.IS..........
THMotorsports has done it again! We have put together another clutch kit for those of you that need something this is EASIER on your pocket and performs just as good as OEM and better.
CLUTCH:
The Clutch Kit is made of OEM grade from EXEDY and has everything you need for a proper and full installation. You can expect a factory smooth clutch peddle feel that is more direct and responsive.
FLYWHEEL:
Fidanza Aluminum Flywheel, very common to use on our cars here and a well known piece. No need to resurface this unit as you can change out the friction plate for very little if you ever need to. The unit maintains some good mass but cuts out a lot of dead weight since you will be changing out the factory dual-mass unit for this.
Additional:
In the kit, there is grease, pilot bearing, throwout bearing of OEM grade and flywheel bolts since your factory ones should not be re-used!
KIT INCLUDES:
EXEDY OEM FLYWHEEL
FIDANZA ALUMINUM FLYWHEEL
FLYWHEEL BOLTS
THROWOUT BEARING
PILOT BEARING
GREASE
ALIGNMENT TOOL
COST: $575 SHIPPED
If you do want to go with a unit that does hold more power with an OEM peddle pressure, you can always check out the original clutch kit we compiled at:
http://my.is/forums/f180/thmotorsports-custom-stage-2-clutch-flywheel-combo-699-shipped-compeititon-clutch-425764/
Thank you!!!
