1 - 13 of 13 Posts
· Registered
After spending 15y without having a car, I moved to LA, from abroad. So, since I had to own a car, I decided to go with something that I had a chance of enjoying. So, there's that - I bought possibly the cheapest (2001) is300 one could. Not the best kept car, many things to fix, and maybe some of them un-fix-able (unreported collision? maybe). But the engine seems to be running amazingly well (so torquey!). I've had the car for less than I week and I think I already love it. I hope I can fix the most obvious issues with it (shaking badly at 50mph and over, and even worse when breaking - but at rare times it goes away?). I intend to use it mostly on weekends, since I've been able to commute to work without it.
Wheel Tire Car Vehicle Window
· Registered
Looks good, these cars are die hards they can take a beating and keep chucking. I purchased mine some years back and it was a hunk of junk, i bought it for 3k and put 1k into the engine and suspension. After that it drove like a champ and the only thing left to do was cosmetics which came way later. You did the right thing buying an IS300 you will have a reliable vehicle for a long time.
· Registered
Start by ensuring the tires are good to go.
You didn't mention mileage, but your car is probably (more than) ready for a full suspension rebuild. I've found the #2 bushing can cause your problem specifically. Figs Engineering sells a nice polyurethane replacement.
· Registered
Welcome! the intermittent shaking could very possibly be shot control arm bushings, i had a similar problem on a LS460 when the front lower control arm bushing completely detached so under heavy braking, the entire arm would move forward 2 inches along the bushing and change the alignment, if i don't accelerate and force the control arm back in place, the car would vibrate.
· Registered
One weird feature of that shaking is that it is not always-always. If I keep on the freeway, it gets worse (especially when breaking), but then, from time to time, it goes completely away (even at the common 'shaking speed' ~ 60mph... that made me into thinking it shouldn't be the usual culprit (ie. warped rotors). The tires are definitely good, and there doesn't seem to be any hard issue with the wheels themselves, they have some scratches, but nothing that looks terrible. The car is also not pulling to any side, which makes me think that the alignment shouldn't be off by much.
1 - 13 of 13 Posts
