1 - 18 of 18 Posts
on the way home with my new car i noticed the steering wheel was not centered, its off about 3 degrees which makes it enough to be irritating. just hope no one else has this problem. i didnt want to take the car back today so i kept driving!! the car is great otherwise!. also, wondering if anyone purchased the teflon coating for the paint or the interior protection system (which i think is just scotch guard)? they were trying to charge $450 for both!
The teflon coat stuff is a bit of a con too. You'll get locked into a loop of special waxes and still have to renew the teflon periodically (every couple years I think). This advice came from a BMW body shop supervisor.
Any of you guys notice a shake in the steering wheel around a certain mph ? I noticed it on the test drive car, but thought it was because people had been abusing it... but when I got mine, I felt that same slight shaking of the steering wheel, and even the front of the car itself. Almost as if it the tires needed balancing... anybody else notice this ?
alignment for a brand new car....that sucks! i hate to take the car back and have the service guys get trained on my car!!! after forking out 35K I'm pretty upset the cars not perfect!
If the steering wheel shakes, I think that's a sign that the wheels aren't balanced correctly.
--k
[This message has been edited by chiem (edited July 09, 2000).]
My father has had the same problem with his GS 400. They put the 17s on the computer and sure enough they needed balancing. These 17s are very finicky.
There was a really long check list somewhere of what to do when you pick up a BMW. The list is easily adapted for Lexus. It specifically states having the alignment checked because of unforseen problems in transportation. I have always insisted that the dealership balance the tires and check the alignment when I have picked up a car. So far, out of 15 new cars I bought, only 2 didn't have some sort of a problem. GET IT CHECKED OUT!!
The 30 day/1000 mile service is a free inspection...perhaps the dealer will do an alignment and high speed balance at no charge....if that doesn't address the shimmee, you might have other issues..
Stop whining and just take the car back and get the steering wheel centered. If the car tracks straight and just the steering wheel is off-center, then a minor front toe adjustment will fix it. I'm sure the service guys already know how to do alignments. I don't care how much you spend on a car, nothing is perfect!
This is funny. I thought Lexi were perfect. Actually, you may be able to have a local mechanic do it. If it uses a steering box, usually there is lock nut on top that allows adjusting the steering. I have adjusted it on my M5 and I can really get the wheel off center if I do it wrong. It was just missed by the dealer. Unless the car isn't tracking correctly I would stay away from the toe adjustments.
1 - 18 of 18 Posts
