I don't think so, but it will reduce gas mileage and the crisper shifting may be uncomfortable for some folks. It also seems to accent the 1 - 2 shift drag so you end up with actually worse acceleratiion from dead stop.Benign said:will constant use of the power button damages our car?
I think I've had my power button on for around 11,000 miles and it still runs as well as it did from day 1bartkat said:I don't think so, but it will reduce gas mileage and the crisper shifting may be uncomfortable for some folks. It also seems to accent the 1 - 2 shift drag so you end up with actually worse acceleratiion from dead stop.Benign said:will constant use of the power button damages our car?
there is no worse acceleration from using the power button.bartkat said:I don't think so, but it will reduce gas mileage and the crisper shifting may be uncomfortable for some folks. It also seems to accent the 1 - 2 shift drag so you end up with actually worse acceleratiion from dead stop.Benign said:will constant use of the power button damages our car?
If you have the 1-2 shift sluggisn, slppy probblem. using the ECT power will make your WOT acceleration slower.dpatterson069 said:there is no worse acceleration from using the power button.bartkat said:I don't think so, but it will reduce gas mileage and the crisper shifting may be uncomfortable for some folks. It also seems to accent the 1 - 2 shift drag so you end up with actually worse acceleratiion from dead stop.Benign said:will constant use of the power button damages our car?
here is what it does:
makes the shifts higher.. no power button- car shifts around 3,000 rpms
POwer button ON- car shifts around 4,000rpms
also, the power button makes it easier for you to get into the higher end of the RPMS while driving.. it also makes the gas pedal more sensitive and easier to push down.. no joke.. go try it.. power button on- pedal is really feathery... power button off- gas pedal feels firmer...
it is true you will lose gas mileage with the power button on.
if you are thinking of asking "why", look above and re- read..
i dont agree with that, but i might not be getting what you are saying 100 percent.bartkat said:If you have the 1-2 shift sluggisn, slppy probblem. using the ECT power will make your WOT acceleration slower.dpatterson069 said:there is no worse acceleration from using the power button.bartkat said:I don't think so, but it will reduce gas mileage and the crisper shifting may be uncomfortable for some folks. It also seems to accent the 1 - 2 shift drag so you end up with actually worse acceleratiion from dead stop.Benign said:will constant use of the power button damages our car?
What's your highway MPG running with the PWR buttton on?NItrouS 300 said:Using the PWR button equals BETTER gas mileage if you learn how to feather the pedal correctly.
I've been running PWR for about 18,000 miles and recently tried taking PWR off to get better gas mileage.
After four gas refills, I found that I dropped about 1.5 miles to the gallon.
The difference is in the amount of control you have. If you watch your "useless" MPG gauge you will see that if you are going over a slight hill without the PWR button engaged and are slugging in a high gear at low RPM, that the MPG hand drops to about 10, however if you engage the PWR button which will make the car downshift a gear to bring the RPM up to something a little higher, therefore allowing you to give a little less to the gas pedal, the MPG hand will be at like 25.
Check it out sometime. The bottom line is that the PWR button allows more control of the tranny therefore allowing the user more control of gas mileage performance.
JM2C
dpatterson069 said:the only sluggish flaw ive seen in my is300 is at 75mph, if you accelerate , at 80mph , the rev limiter kicks in, and when this occurs, the car seems to lag in acceleration for a second.. but then jumps back in and accelerates really well.. many people have that problem..
yea, no one can seem to pin point this problem.. its really bothersome at times... if i accel after 80mph, its not there.. its just inbetween 73-79mph..GJ said:dpatterson069 said:the only sluggish flaw ive seen in my is300 is at 75mph, if you accelerate , at 80mph , the rev limiter kicks in, and when this occurs, the car seems to lag in acceleration for a second.. but then jumps back in and accelerates really well.. many people have that problem..
Yeah i have this problem too =( However, I don't think it's the rev limiter kicking in. I had a tech come for a ride with me, he noticed it as well, but they haven't resolved anything yet. I'm pretty sure he just wants to blame my mods, but of course this isn't the cause of it if ppl have been having this problem with only an after-market exhaust installed
yea, it was called the trac/ecu update... which i did.bartkat said:The 1-2 shift problem on 2001 and early 2002 models has been documented and service bulletins were issued, and the "fix" made for those who returned their cars for service.
I've never experienced any problems in the 75 - 80 MPH range, but I belive 80 MPH is about where the trans shifts fro 3 to 4.
