1 - 20 of 28 Posts
Tein SS
The ride in the beginning is really bouncy because the shocks need to break in. Once the shocks settle you'll notice a stiffer ride. Overall the SS is great for handling performance. There is occasionally a knocking noise coming from the suspension, I hear other people have this issue as well from similar suspension mods.
i think that they are great. i have had mine on for about 4 monthes already. i think the ride is stiff at the recommended setting of 6. i keep my front at 6 and rear at 7. i haven't adjusted them since i got them installed and probably won't. it's a good setup if you don't have the money for the flex. definitely a good buy.
Re: Tein SS
A couple of questions:
1.) How long is the "break in" period?
2.) What damping settings do you have them set at?
3.) Do you have the EDFC?
3a.) If yes, then do you notice a large difference in stiffness between the top and bottom damping settings?
3b.) How does the lowest damping setting compare to the stock Lexus suspension in ride and handling?
Thanks for your help!
1) break in period - a month maybe, i dunno
2.) What damping settings do you have them set at - 6 in the front, 7 in the rear
3.) Do you have the EDFC - no EDFC, but you can get it for the SS
3a.) If yes, then do you notice a large difference in stiffness between the top and bottom damping settings - haven't tried driving with different setting yet.
3b.) How does the lowest damping setting compare to the stock Lexus suspension in ride and handling - someone else will have to answer
Re: Tein SS
Not sure if this is true - it might just me getting used to the stiffer ride. It does ride smoother after a month or two
Front 0 / Rear 0
Nope. Pointless unless you adjust it often for daily/track use
I had it at F/R 6 and it was a lot stiffer than the 0 setting. Full firm is just going to be ultra stiff and not very drivable
Softest setting is still much stiffer than stock or eibach/blisten combo because the spring rates are still F12 R10. Get the Tein CS (F8 R6) or Apex-i WS Dampers (F8 R6) if you need a smooter, more comfortable ride.
$lores amongst us!
I just ordered by Tein SS Dampers from Carson Toyota today and I would like to thank all those that chimed in on this thread. They'll go perfect with my 19's I just ordered :D :p . Pics coming soon.
BTW, Carson is running a special on the SS's for 850 + 20 for shipping.
$lores amongst us!
Discussion Starter · #13 ·
Well I had my Tein SS Dampers installed today and I must say MAN I LOVE THEM. The stance of my IS is mean and agressive looking. I went around a turn at a pretty good pace and there was barely and body roll.
Again thanks to all that helped me in my decision. 8)
$lores amongst us!
wut are ur damper settings>? how low did u go? got any pics yet?
Justin
I currently have the dampers set at neutral and the car is pretty low but the wheels are NOT tucked. Sorry no pics yet until I put on my new wheels once the rears finally show up :pissed:
I just got my Tein SS installed an hour ago and i absolutly love it. I got the Giovanna Seki's in 18"s. (hyper black on a GGP) I think it looks pretty good, I'll post pics as soon as i get a hold of a digi camera.
I got charged $250 for my installation, and I got some free bulbs :)
Don't forget to get the EDFC! You won't regret it! Installation was a breeze. You'll have more control over your suspension with these things.
$lores amongst us!
I think I will have to invest in the EDFC. Where can I get it cheap?
I was pretty strapped for cash, so my thinking was, if I could've afforded the edfc, I would have got the FLEX not the SS. (even though Im very happy with the SS so far)
1 - 20 of 28 Posts
