I'm ready to finally purchase some tein s-tech springs. I debated abuot these and H&R and it seemed I would have less problems with these. After reading lots of posts, I'm not sure if I should buy aftermarket shocks as well?? I want to keep the stock smooth ride. Give me your thoughts. Also post some pics if you have tein s-tech on stock wheels
I got the S Tech's on my car a week ago. It says 1.5 front and 1.6 back, but mine is 2.0 all around im guessing. it went a little lower than said. :-? Also, the rear camber went bad just a little, the tires are out now. I will be getting an alignment this week, so hopefully that gets better.
when i got my stechs installed....the ride quality of the car was still good
stock shocks where holding fine....
but i highly recommend you get your car re-alligned a week after the install since you will have camber problems which will lead to wearing out of tires alot faster.....give it a week to let the car fully settle.
the car will ride fine with stock shocks....mine got blown from an accident, not the wear from the springs
the stechs look like a 1.5 in the front and 1.75 in the back
looks fine on my car....
the H&R are 2inch drop...wanted those, but got a deal on the tein's
i scrape sometimes going up my steep driveway.....
good luck
Ehh Jeff I highly recommend getting aftermarket shocks. Its just alot more smarter to do for now and for the future. Search and you'll see why. I highly recommend the Koni Yellows... i too also am riding on the Koni yellows' w/ Tein Stechs...
I dont know if you noticed how low my car was that day we met up but Its a perfect drop IMO. The tires just almost barely begin to tuck while the ride quality is great unless your going 70 and hit some bumps which then you'll start bouncing a little bit... but then again i'm on a really soft setting. PM me if you have any questions.
PS is300soon has the best prices for the Koni's IMO>
I thought I should go with TEINS at first...
Now its all save up for ZEALS baby
Threadlocker
if you lower it with stock shocks, the actual drop will be more than the 1.5/1.6 that the tein springs are rated for.
personally i'm using tokico illuminas, and they are just fine. a bit stiff if you hit consecutive bumps, but otherwise the ride is close to stock (on the softest setting)
