Ok guys i have been doing alot of research and have found alot of positive things being said about both the Tein Flex and HA. The flex's have springrates of 10 kg/mm front and 8 kg/mm rear. The HA's have 12 all around.
The one thing i'm worried about with the flex is the spring rates being too soft. Now the car is daily driver, but i like to hit up twisties and auto-x. The auto-x isn't all that serious, more of a fun thing i like to do. The one problem i can see with the HA's is that they are 12 kg/mm spring rate front and rear and am not sure if this can upset the car's weight distro of 54/46 (front/rear).
I am being offered 2 sets of flex suspension in perfect working condition. Out of the 2 HA's that i'm being offered, 1 of the sets has a blown shock which will need revalving and the other set has rear shocks that make noises going over bumps and such. I have read that the noise issue can be fixed by tightening the top bolt on the coil with an airgun (?).
Any help yall can give me will be greatly appreciated. Please vote on one!!!
Thanks guys
Thanks guys
