I am looking for some info/feedback on the Tein CS coilovers. What spring rate do you have 8/6, 9/7, or 10/8? Did you have any kind of suspension upgrades before hand? And lastly, did you have these and then upgrade to another suspension, and if so how do they compare?
I currently have Tokico Illuminas with Tanabe GF210 springs. I am in between the KWs and Tein CS, partly is money (KW>Tein), and the other is ride height adjustment, Tein seems to beable to go lower, however the KW 2.4"ish should suffice my needs....
Not sure on the spring rate but I have what came on my tein cs. Ride is better
than stock. I had underbraces and a rear strut tie bar this for sure helped the handling and a bit with body roll.
I used to have Tein CS (gold)...Not sure of the spring rates but it rode really well until i blew one of the front shocks...Im currently running Mono Flex and couldn't be happier...
