1 - 12 of 12 Posts
Can I see some pic of your Teck 12v Grounding Kit installed in your engine bay because I'm planning to install my during the weekend and the instruction is in black color and it is hard to see...
Send me your email address. I have the instructions in PDF file (with color pics). -C
what should i use to loose up the nut bolts that needs to be tap on the negative cable of the battery because i had a problem unscrewing it..It's mad tight..
Am I missing something here? looks like 4 gauge wire with gold plated terminals . . . might be able to find the same stuff at your local car audio shop, lol.
It's cut specifically for IS300 and the terminals are soldered.
You're missing IDEA,LABOR, RND, INSTRUCTIONS. Those don't come from a local car shop.
1 - 12 of 12 Posts
