So it has been not even two weeks and already my first 1000 miles are behind me. The car is still running strong. Nothing has gone wrong (knock on wood) not even the slightest inclination of a problem. The coolest thing is that with my nice quite exhaust (Borla) the car is stock quite at idle and part throttle. It is only when you stomp it and the WG opens that it sounds like the monster it really is. However, the borla is coming off soon in favor of a more open flowing design to free up some more HP. So far the only modifications I have done from the way TE set me up have been to remove all but two of the washers in my BOV (now I get "pssshhh" instead of "wa ta ta ta ta") and to add a greddy catch can.
The mod bug is knocking at my door once again.
For the next round of mods
Cross Drilled and Slotted Rotors
Semi-metalic pads
SS Lines
And better fluid
AEM Wideband
Greddy Profec Type S boost conroller
Greedy Turbo Timer (maybe)
TE injector Upgrade
Trans Cooler
Invidia N1 70mm exhaust
I won't really be cranking up the boost just yet. I am trying to build up in a way that I can have peice of mind about my motor and trans.
Semi-metalic pads
SS Lines
And better fluid
AEM Wideband
TE injector Upgrade
Trans Cooler
