I think you are looking at the PLP Powerdyne sc and not the vortech scstick said:The TBKO stage 1 will put out about 310-320rwhp (auto--according to Jeff) and 320-340?rwhp (m/t), whereas the PLP Vortech will have about 250?rwhp? (auto) and 280rwhp (m/t--Mike's current IS). You would be giving up a bit of whp between the two. The turbo will cost more to install, but it is $500 less in price. I am still deciding between the two :-?
Does that mean yours was a TBKO custom? :wink:IS300GTE said:there is no stage 1 or 2, its just the tbko turbo kit
anything above the capabilities of the kit is considered custom
-gte
goldark said:I think you are looking at the PLP Powerdyne sc and not the vortech scstick said:The TBKO stage 1 will put out about 310-320rwhp (auto--according to Jeff) and 320-340?rwhp (m/t), whereas the PLP Vortech will have about 250?rwhp? (auto) and 280rwhp (m/t--Mike's current IS). You would be giving up a bit of whp between the two. The turbo will cost more to install, but it is $500 less in price. I am still deciding between the two :-?
stick said:goldark said:I think you are looking at the PLP Powerdyne sc and not the vortech scstick said:The TBKO stage 1 will put out about 310-320rwhp (auto--according to Jeff) and 320-340?rwhp (m/t), whereas the PLP Vortech will have about 250?rwhp? (auto) and 280rwhp (m/t--Mike's current IS). You would be giving up a bit of whp between the two. The turbo will cost more to install, but it is $500 less in price. I am still deciding between the two :-?
Mike had his Vortech at the Carson meet and he said in dynoed at 280rwhp (he had a m/t). Maybe the auto will dyno at 265rwhp?
Mine's on factory rims. I'm happy to volunteer as a tester...and I'm local :wink:IS Pilot said:Yes, 7psi 280whp manual with 19" rims (due to the brakes). We are not posting any dyno's until we have another local Vortech install with factory rims. One thing you guys have to remember is some of the extra power from the turbo comes from removing the factory cats. Do the same to any PLP kit and you will see 5-10% better numbers. PSI for PSI the turbo will be slightly higher since the sc's are more parasitic in its design.
Mike
blue_j said:Mine's on factory rims. I'm happy to volunteer as a tester...and I'm local :wink:IS Pilot said:Yes, 7psi 280whp manual with 19" rims (due to the brakes). We are not posting any dyno's until we have another local Vortech install with factory rims. One thing you guys have to remember is some of the extra power from the turbo comes from removing the factory cats. Do the same to any PLP kit and you will see 5-10% better numbers. PSI for PSI the turbo will be slightly higher since the sc's are more parasitic in its design.
Mike
but I'm sure you probably meant a paying install![]()
