My tailliights will not come on when I turn on the lights. They only work when I hit the brakes, and that's it. I know it's not the bulbs because the brake lights still work. Does anyone have any idea on how to fix this?
Change the bulds......the bulbs are combination tail/brake light bulbs (7443.double end bulbs.
Is there an orange warning light on your gauge cluster? If so then YES as mentioned change the tail light bulb and it will go away.
dual filament bulbs. one burnt out
yup needs to be replaced..had the exact same problem
found it
I changed my bulbs, but then I found out it was a burnt fuse
thanks anyway
