I am in the process of swapping out my tail lights. However I have encountered a problem. Two square bolts that are actually attached to the housing. How have you all dealt with taking your tail lights out. Any help would be great. Thanks in advance.
Threadlocker
um. WHAT?
you don't need to remove the trunk liner to take off your taillights.
1. open trunk
2. pop the black screw covers on the front side of the tail light.
3. unscrew two bolts for each tail
4. remove tail light.
yea you dont have to take anything out from the actual inside of the trunk. its just the two screws on the seam and then the light will just come out.
Put your trunk back together and remove the two plastic screw covers on each taillight. These are located in the black part of the tail once you open the trunk. Once removed they should pull out..
God dammit, thanks guys. Glad to see I wasted some time. Di Ti Di
