Timing belt
Tensioner
Idler
Drive Belt (Serp)
Water pump
T/stat
T/stat gasket
PVC (5/2001 and up)
O-ring Bypass pipe
O-ring Bypass Outlet
Valve Cover Gasket (intake side)
Valve Cover Gasket (exhaust side)
Cam Seal x2
Crank Seal (front main)
Spark plug x6
Air Filter
And then of course BC stg 2's and a cam gear.
Anything else you guys can think of that I should order/do while in there?
Super Moderator
Toyota black gasket sealant
Intake manifold gaskets if you want.
Remember tight side of oem on cams for clearance
Also clean out throttle body
Super Moderator
Good call Tom...
It was mentioned to add a dab of some silicone sealant to the front corners of the valve covers and where it goes over the cam cap. This is to prevent leaks and done as a precautionary, otherwise it will leak.(remember only 75 IN/LBS.).
Have a friend who is a Toyota tech who will do the work. He will supply the coolant. I will ask him about the silicone sealant trick, but I'm gambling that he already does it.
Shims will be based on if I need them, and will be seen during install.
Thanks guys
