1 - 19 of 19 Posts
I Just lowered my car on Tein type CS coilovers. Ride is great ya de da. Here is the problem my ABS light stays on and my Traction light keeps on blinking i took off all the tires again and check all of the wires going to all four calipers and they all seemed to be fined and i also reset the ecu and i am still having the problem!!!!!!!!!!!!!!!!!!
PLEASE HELP I DO NOT WANT TO TAKE MY CAR TO LEXUS
Penetration Specialist
Thats interesting. Coilovers are an easy install...just a few bolts here and there. Did you loosen anything other than the top three bolts and the lower bolts on the control arm?
yes
I used to be a honda GOD now i moved over to lexus and it was a lot different from a honda. so yea i know for a fact i loosened more bolts then i really should haved but everything put back together nicly and it rides pretty nice so i have no clue
Re: yes
Did you touch the brakes at all...cause you don't have too...like I said...its a pretty easy off with the old and in with the new mod.
what do you mean
I was stepping on the calipers to move the lower control arm down so i could pull out the stut i used to do it to honda all the time so i guess i shouldnt do that, but what is the problem i am not a newb i know how to work on cars
hey
by the way how do you like the toms bracing i was think of using Cusco my car is only 3 weeks old so i am new to toyota
Re: what do you mean
hmm...maybe someone else knows what happened. I would just suggest looking over everything....take the wheels off and see if anything looks awkward?!
Re: hey
The Tom's bracing is great! My car handles like it is on rails..very nice!
Discussion Starter #9
well thanks for helping
yea it looks like thats all i can do but can i take off those brake wires at all and just put them back on or will that mess them up and how much do you think it would cost to fix if i took it to lexus
If everything looks ok then I think that you prolly stretched out your abs speed sensor wire. It it a fiber optic cable ( what the tech told me) and it is delicate.
The only way to know for sure is to go to a diagnostic place that can read the code. If it says it is the abs speed sensor then you have to go to the dealer to buy a new one and it is a pretty easy install.
Discussion Starter #11
thank you
thanks alot all you guys for helping me i appreciate in greatly i will check out everything and all the thing you say seem to make sense so thank you very much. You guys are awesome. I am sure i will be asking you guys alot more questions cause i have alot of plans for my new IS. :D
I dont think the abs speed sensor wire is a fiber optic cable. I highly doubt that a system for speed sensors would use fiber cable. I use fiber optics here daily and it requires a grip of equipment. I'm pretty sure your tech lied to you on that one.
Discussion Starter #13
well then
i looked at the wirs much moree closer and they seemed to be really fine i live in orange county california is there anyone i can see that is not a lexus dealership that can help me out
You ripped the wires inside one or both of the speed sensors, they are very easy to change but are 200 bucks each. Thats your problem.
The part numbers you need are:
Right: 89542-51010
Left: 89543-53010
Thats the only way to fix the problem.
Discussion Starter #15
Ok cool
how do i find out which one i ripped i looked and i could not see anything, nothing on the outside, the money is nt an issue i just want to know which one is broken without taking it to lexus and is it only the front. What do you think it would be front or back i think the front do the back wires usually do this. or is it usally the front
Discussion Starter #16
oh yea
one more thing should i not drive my car cause i would like to fix it next friday if possible or should i fix it right away
There probabbly is a way to find out which one is mest up, I ended up changing both and 99% of the time the problem is in the front, the rear ones are not in the way when you take the shock off and they have a much larger slack in them.
Discussion Starter #18
carson
Hey you guys think Carson Toyota would help me out if i buy some parts off them. I heard they work a lot with trd and other companies.
Re: carson
I'm sure the Carson guys will help you out. Give em a call or better yet stop by and let them take a look at it. Give Ganz a call or email.
1 - 19 of 19 Posts
