ok so I thought it was just me and that i wasnt used to driving a RWD car and that the back end was just loose, but now that i noticed only the rear right wheel gets "loose" when i go over bumps, it isnt both wheels, could it be the end link?
Check your tire pressure first. What is the pressure in all four?
Are you lowered?
no im not lowered....tire pressure is the same in all 4 tires.
Try jacking that tire in the air and seeing if there's any movement that shouldn't be. You can stick your head under the car too and take a look at the connections, bolts, ect.
What exactly did you mean by loose? If you thought there is movement in the suspension components... then you should check things out.
