These are the Lexus IS 300 Pace Car specs
ENGINE
Type: 2JZ-GE, I-6, DOHC, 24-valve, supercharged
Displacement: 2997 cc
Power: 265 @ 5800 RPM
Induction: TRD Supercharged
Bore: 3.38 inches
Stroke: 3.38 inches
Compression Ratio: 10.5:1
Fuel: 100 Octane Unleaded
Exhaust: Borla Custom Stainless Steel Exhaust
DRIVE TRAIN
Transmission: 5-Speed Manual
Gear Ratios:
1st - 3.285
2nd - 1.894
3rd - 1.275
4th - 1.000
5th - 0.783
Final Drive - 4.08
Clutch: Centerforce Single Disc
CHASSIS/BODY
Chassis: Unibody
Body: Lexus IS 300
Steering: Power Rack and Pinion
Seating: 4 Seater
Paint: PPG Automotive Finishes
Graphics: Molly Designs
SUSPENSION
Type: Independent
Front: Double Wishbone Eibach Racing Coil Springs
Rear: Double Wishbone Eibach Racing Coil Springs
Shock Absorbers: Bilstein
WHEELS AND TIRES
Wheels: BBS
Front - 18" x 8"
Rear - 19" x 8 1/2"
Tires: Bridgestone Potenzza SO-2 Pole Position
Front - 225/35ZR/18
Rear - 245/35ZR/19
Brakes: Front- Brembo Four Piston Caliper w/ 12.9" floating ventilated discs/Rear - Single Piston Caliper w/ 12" rotor
ADDITIONAL FEATURES
Safety: Full Roll Cage, Four-Point Racing Safety Harness, Competition Shock Absorbers and, Springs, Safety Fuel Cell, On-Board Fire System, Safety Strobe Lights
DIMENSIONS
Race Weight: 3270 Lbs.
Wheel Base: 105.1 Inches
Overall Length: 176.6 Inches
Overall Width: 67.7 Inches
Overall Height: 53 Inches
Ground Clearance: 4.7 Inches
Track Width: Front - 58.9 Inches/Rear - 58.5 Inches
Fuel Capacity: 22 Gallons
ENGINE
Bore: 3.38 inches
Stroke: 3.38 inches
DRIVE TRAIN
Gear Ratios:
1st - 3.285
2nd - 1.894
3rd - 1.275
4th - 1.000
5th - 0.783
Final Drive - 4.08
CHASSIS/BODY
Chassis: Unibody
Body: Lexus IS 300
Seating: 4 Seater
SUSPENSION
Type: Independent
WHEELS AND TIRES
Wheels: BBS
Front - 18" x 8"
Rear - 19" x 8 1/2"
Front - 225/35ZR/18
Rear - 245/35ZR/19
ADDITIONAL FEATURES
DIMENSIONS
