Stock summer tire life time
1109 Views 2 Replies 3 Participants Last post by  SilverLex
My rear right tire is flat. I've had the car since Dec 2000 and have put on about 14,200 miles since then. How long do the 17" tires last typically? I drive mostly highway 70-80mph. Should I go ahead and replace all 4 tires or are they meant to last much longer?
Thanks,
Train
Thanks,
Train
It really depends what level of performance you expect. You could run them 'til they're bald for 20-25K miles, but wet handling would suck and you'd risk being in an accident from sliding all over the place. Dry grip would suffer too, but not as bad.
If you want the highest level of tire performance you should get new tires when your current tires are 1/2 to 2/3 worn -- which would be now.
It really all depends on your budget and your tolerance for less than stellar handling AND braking.
Write customer service and give them your VIN to see if you qualify for a new set under campaign 1LD. They answer within 24 hours.
