· Registered
Does anyone know where I can get an amp-turn on line? Usually the blue colored wire... I tapped the gray wire coming from the stock amp for a while, but that was taking too much current away and caused the stock amp to shut off. Thx.
· Registered
Talk to a stereo shop about using an "SCR" on the gray wire so that it is just used as a trigger wire rather than a power source.
[This message has been edited by TEG (edited October 11, 2000).]
· Registered
that wire is called the "remote" wire i beleave. It's a low volt signal that tell's the amp when the radio come on.
Martin
Black/Ivory IS300
· Registered
Does anyone have access to an electical manual for the IS so we can determine exactly what the gray wire is and what other wire(s) might work?
HackerBenny:
I have my sub amp hooked up with the gray wire as the amp turn-on (based on your original post). My system seems to work fine. What symptoms did you have that made you think this wire isn't good? Maybe my amp uses the turn on differently than yours. Neither one should be drawing much current at all. I've played my system at 12:00 for an hour straight without problems.
Rob
2001 IS300
Spectra Blue Mica/Ivory
LS, LD, HH, SR, 17" wheels
2000 Jeep Grand Cherokee Limited
4.7L, QuadraDrive, UpCountry
Patriot Blue, Fully loaded
· Registered
12:00 huh? That's what I did too. I had it turned up to 12:00 with my favorite ATB song and then -silence-. >.< I turned off the ignition and turned it back on and still no sound. I was really having a cow because at that point I thought I blew my stock amp (six days after buying the car). I disconnected the gray accessory 12 volt wire from the MTX amp and still no sound. I ended up calling the dealership and made an appointment to have my stereo looked at. The guy even said something along the lines like.. "Oh.. You installed your own stereo. That voids your warranty". Before I brought it in, I made one last effort to check my wiring and look for any broken fuses within the amp casing. It had two fuses which were still in tact. As a last ditch effort, I just took a screw driver and shorted the 12 volt constant with the 12 volt accessory and DAMN! It worked. Somehow that reseted the stock amp. Since then, I have been pretty scared to even turn it up past 10:30. I have the gain on my MTX set to about 20% right now.
Did you tap your front left and right speakers for the signal to your amp?
· Registered
Yep, got the amp signal from the front main speakers, thanks to your install instructions. In fact, everything you documented was spot-on.
Good luck with your amp situation...
Later,
Rob
