On an IS350 with no nav and no sat radio,
What is the graphic with bars at the bottom left corner under ASL? If that is a signal strength indicator, what is it the strength of? Satellite signal?
In mine it is never more than one or two bars. I can't believe that if it is the satellite signal, that it would be that weak if I ever decided to get XM.
Also, is only the sat radio antenna actually in the shark fin or does that serve the FM/AM as well? I think I read somwhere the FM/AM may be in the roof.
Couldn't find any of this in the owner manual - thanks
If the Automatic Sound Leveliser (ASL) is set to "ON", it bascially compensates for ambient/background noise levels & adjusts the volume/other audio sound parameters accordingly. For example, driving faster or over a roughly paved road, you would normally see more bars on the graphic strength indicator i.e. more ambient noise & ASL will move to compensate accordingly. That's the theory behind the function anyway - with 4years in a 2nd Gen RX & another 2years in an 2nd Gen IS, I have not noticed any perceptable differences between ASL "ON" & "OFF"
Thanks.
For me, the graphic goes up and down randomly, with no change in volume. Pretty worthless feature if you ask me. Should have filled out my customer satisfaction survey!
