Hi Folks,
As some of you may have know I decided to replace my stock leather steering wheel by a brand new carbon fiber one with the up/down tip-tronic feature.
After speaking with some of the South Florida crew at the JM meeting this past Sunday I finally decided to do it myself (a good shop would charge between 200$ and 500$ for the install) so I went ahead and did it myself for a 25$ cost! I created a tutorial for whomever wish to install or remove your steering wheel.
This tutorial is to be used as reference only and I cannot be held liable for any incorrect information or wrongdoing if you were to attempt to do the install/removal yourself!
Please note that tempering with the airbag could lead to serious injuries or death!
Tools needed:
T30 Torx wrench
Heavy duty Steering wheel puller (25 $ for the kit at AUTO ZONE) comes with clear and easy instructions
Adjustable/Monkey wrench with different bolts size
1st -start by aligning your wheel straight, then unhook your battery to avoid any issue with the airbag (let the car seat for 30 sec so all the power comes out from the steering column):
2nd- locate the 2 Torx screws that you will remove (they are behind the steering wheel near the up button on the back):
3rd - using the T30 Torx wrench unbolt the 2 Torx screws on each side behind (left and right). Be careful as they might be hard to unbolt, so try to hold the steering wheel with one hand while using the other as a lever. The airbag cover and the airbag will come right off! Be careful when pulling out the yellow socket which is the airbag connector:
4th - Disconnect the white connector from the steering column wire spindle. This connector contains the wires for up/down shift and cruise control. Pull slightly towards the bottom:
5th - use the adjustable wrench to remove the center bolt; you may want to use a little force when doing that as it is tightly bolted:
6th - When the bolt is finally out it should look like this:
7th - Get your steering wheel super power puller kit and follow the install instructions. Make sure to keep the column steering straight after the steering wheel has popped out for an easy re-install.
That's what the puller kit should look after you 've removed the wheel:
8th - Put the new steering wheel back on; reverse engineer first by bolting back the center bolt then plugging back the white socket, then the yellow one onto the airbag unit, then wrench back the 2 Torx screws on each side....
and VOILA:
Thanks for looking and share some + rep if that was helpful :approve: !
Don-
PS: The old steering wheel is for sale check the market place (it has no rips or nicks)
Tools needed:
T30 Torx wrench
and VOILA:
Don-
