1 - 20 of 20 Posts
just like the subject says... my steering wheel isn't centered right anymore...
when im going str8...the wheel is turned slightly to the left... facing about 12:45-1:30...
is there any easy fix for this?? i find that it makes me drive a little more unstable at times..
Penetration Specialist
uh...you might want to take it in to get its alignment. That is most likely the problem. Have you hit any potholes/curbs recently?
O.k.... I'm so confused! Where is 12:45-1:30 :crazy: :lol: :lol:
there is a service bulletin on this, ill try to print it out. I am not sure if it's the same exact problem, but there is a Service Bulletin for the steering wheel. Just check out the general discussion forum, ill try to post up all the Service Bulletin for our car.
it's starting to be a known problem. Check tomorrow for listing for SBs. I will list them, and from there on, you make the judgement of whether the SB is ur situation.
yes... thats the same as mine lol.. going straight but steering wheel is off center to the right.
and no, i haven't hit any potholes. the alignment doesn't feel off. the car doesn't swirve off the road if i dont hold the wheel. but i should get an alignment soon.. too dayum lazy to raise my car up... everywhere i went for an alignment said my car is too low for it. lol
All the TSB does is give the procedure for checking and lining up the sterring wheel.
Most often the cause is that you need an alignment. Get the wheels lined up and then have them center the wheel.
And yes, it's a known problem that's been around ever since cars existed almost.
Discussion Starter · #14 ·
my alignment isnt off as stated in an earlier post. the car does not pull to any side... on a flat road it goes str8 but the wheel isn't facing str8.
thanks for the info tho. imma go check the gd
It's definitely not an alignment problem, although an alignment would cure the problem, but only for a minimum amount of time, after awhile the same problem will occur. I don't know whether the TSB will cure this situation forever, but it's a cheap fix.
Tical--
I posted in the other thread about the TSB. But i will post here as well just incase you dont check one. Your alignment CAN be off and the car drive straight. if your tie rods are off to the point where your toe looks like this
\ / you will go straight. If your toe looks like this / \. you will go straight. The only time you will NOT go straight is if the toe is like this \ \. Thats when the car will go in a direction. Or if the camber in the front is off on only 1 wheel. Kinda get where im going with this? Now, even though by looking at it, it may not be noticable, but every 10th of a degree makes a huge difference. As a matter of fact, IM me or PM me.
Podiatrist
Dan, where da fock is 12:45 - 1:30 hahaha
with 12:45 you have an hour hand as well as a minute hand.
What I'm trying to say is that you get your car lined up before you adjust the steering wheel centering. Sooner or later, almost every car is going have an off center wheel problem. I don't think it's unusual.
1 - 20 of 20 Posts
