1 - 13 of 13 Posts
anyone have a problem with a slight steering shakes at certain speeds? only have 800 miles on the IS and everything is great. only problem is that at speeds of around 48-52 i can feel a very slight shake in the steering wheel. doesn't bother me too much because i'll bring the car in for the 1000 service in a week or so. just curious.
Probably your wheels are off-balance... that's easily fixed at service, just be sure to tell them, and test it to make sure the problem is gone.
Well, I have shake at speed a little higher. I brought mine in to get balanced and the alignment checked out. Everything was fine except the fact that I BENT 2 FU CKIN RIMS!!
Now the shake is buggin the fu ck out of me.... I'm just trying to decide on rims.
Vibrations that come and go at certain speed intervals are 9 out of 10 times a bent rim so that you the vibration is cuased by a physics thing called destructive interference. Basically waht it means is that the wheel is rotating at a rate such that the "woop" spot in the rim causes a bounce that is at a rhythem that the springs cannot compensate. The car kinda bouces up when the srings are still recovering from downward motion of landing on the flat spot.
Hummm interesting enough I'm having the same problems at the SAME speed. Wierd huh.
I took it into the dealer for my 10k service and they said they did a HIGH speed balance on it and it was fixed but I can still notice it.
Also the steering is off alignment just a hair to the left. Meaning that I need to turn the steering wheel to the right to get it straight. Not a big deal but I can notice it.
I too am afflicted by this condition. I've checked and rechecked tire pressure, alignment, time of the month, etc.
Here's an old thread I posted: http://www.is300.net/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic&f=1&t=001325
I've b!tched and cried to Lexus. Their final conclusion was... "It's a characteristic of the vehicle". WTF! I have an official letter from Lexus stating this. I'm really disappointed.
Now I just need Audi to build a stable S4, so I can trade my IS.
do yourself a favor and find a dealer that has a Hunter GSP9700 tire balancer. this device will find and diagnose tire balancing problems.
you need to make sure the dealer has the ability to 'index' your tire/rim combo to find high and low spots on your rim and tires and be able to match it to give you a vibration free setup. if you still have vibrations, then you may have other problems, ie. warped rotors or busted ball bearings etc.
http://gsp9700.com
BTW: Mine is smooth as butter at any speeds. Not a hint of any shake or vibration whatsoever. I have definately had other cars that did this, and there can be lots of reasons:
1> Wheels out of balance (as suggested)
2> Wheels bent
3> Flat spots on tires (from sitting too long or from a lockup brake situation) [ABS probably prevents anyone from having locked brakes so that is less likely]
4> Incorrect inflation
5> Worn out steering bushings (unlikely this soon!)
6> Warped brake rotors. (unlikely this early)
7> Incorrectly tightened lugs.
Anyways - if the balancing turns out to be correct you could look into some of the other possible causes...
dreamSpeeder;
My dealer actually had a Hunter tire balancer. They "told" me that I had a tire that was out of balance - the driver side rear. They fixed it. The problem still exists. Like Lexus said - "characteristic of the vehicle." It sux.
Gotta turn in. Need to wake up in a few hours for a Win2K deployment.
[ May 17, 2001: Message edited by: Watcher ]
most dealers would carry a 'hunter' tire balancer, many won't have the gsp9700. indexing the tires takes a few minutes longer, but gives you a better balance.
dealers tend to say 'it's the way the car was designed' but, when you first bought it, did it shake? probably not.
dreamSpeeder;
I didn't really pay atttention to the car, until it hit 1000 miles. Really drove like a grandma. I started opening it up after that... then I noticed it. I assumed it was there from the beginning.
I noticed that the tires need to come up to temp in the morning. I usually leave at 3AM for work. The car just jackhammers (at low speed >25mph) for the first few minutes. The tires warm up and it's fine.
[ May 18, 2001: Message edited by: Watcher ]
1 - 13 of 13 Posts
