1 - 2 of 2 Posts
My new IS,
Problem with the starter like if it do not drive the engine.
I think it is the magneto on the starter and try to remove it to check it but no access (between the transmission and the body) for the second bolt.(Upper one)
Did someone have a trick or something?
Lower the engine cradle. Then prop up the front end of the motor gently with a jack or something. This will lower the rear end of the tranny. Then use lots of extensions, and possibly a swivel looking from the tail end of the tranny will get you there.
1 - 2 of 2 Posts
