I have no personal experience, but I've heard they make a very good difference in "pedal feel" when upgrading your pads and rotors.
Unfortunately, I also heard that the steel lines will "unweave" over time and will need to be replaced relatively often(every couple of years). Someone please correct me if you know different..........
Threadlocker
SS braiding should NOT unweave if the fittings are put on correctly, as long as they are high quality hoses.
Guru of Supercharged ISs
in a word.
YES
better pedal feel & modulation.... stronger & the only way to go IMO.
for 100-120 bux it is a GREAT and noticeable improvement... good for daily driving if you do not hammer the car hard & the ONLY way to go if you DO..
just do it.
