PFS Lexus IS300 Stage I Shippable Turbo System (Good for up to 340 flywheel HP!)
Look no further for your complete Lexus bolt on turbo kit.This newly developed state of the art Lexus turbo system incorporates the most advanced hardware available. Tested thoroughly on the street and the dyno, this system has unsurpassed reliability to back up its outstanding performance. The Stage I turbo kit for the Lexus IS300 produces up to 340 Horsepower using 7 psi of boost.
This kit includes the following:
PFS divided pulse cast-steel exhaust manifold, 45mm SS TurboSmart wastegate, Turbo Smart Blow off valve, 60-1 Hi Fi series turbocharger, 3" mandrel bent SS downpipe back to the rear axle, 3" High flow catalytic converter, Custom Cool Charge air intake systen with K&N Hi Flow filter, PFS high volume fuel pump upgrade · Custom Electromotive TEC³ engine management system. · PFS Electronics Interface Module · Silicone hoses, clamps, heat shields, and all additional components required for a successful installation.
PFS Lexus IS300 Stage II Shippable Turbo System (Good for up to 500 flywheel HP!)
The Stage II kit includes all of the above components as well as a 3mm metal head gasket, Turbosmart boost controller, large front mount intercooler with 2.5" stainless steel piping kit and larger fuel injectors. This lowers the static compression ratio to a boost-friendly 8.6:1 for more horsepower output on pump gas. Typical installations result in over 400 RWHP at 15 psi of boost.
PFS Lexus IS300 Stage III Single Turbo System
The Stage III kit is intended for applications exceeding 600 RWHP on race gas. This kit includes a larger turbo, larger injectors, return fuel line system. The Stage 3 kit is a custom tailored to fit your power needs, please inquire for additional information.
NOTE: The following prices do not include installation.
PFS IS300 Stage I Single Turbo System IS-ENG-PACKAGE Price $ 5995.00
PFS IS300 Stage II Single Turbo System IS-ENG-PACKAGE Price $ 8995.00
