1 - 20 of 36 Posts
Which one is the better bet in terms of power and performance. Price seems very close and installation about the same. I just spend $650 on headers and install, so I'd hate to throw that away with the turbo. Need some opinions here. Also how important is the intercooler for either the S/C or turbo? My mechanic said it is almost a neccissity for either one for them to operate effeciantly.
Thanks :chill:
Compare the dynos and the prices, and the choice will be obvious.
Don't throw away the header- you can easily sell it on .net, probably only take a 30% loss or so- Also, the SRT stage 2 comes with a big FMIC, my intake air temps have been remarkably low.
If you really are interested, give both prolex and SRT a call, and have a long talk with both places, discussing what you want in a kit, and see which one will really suit your needs the best- that is the only real way to make a decision.
Granted, I'm biased, but I have a feeling you will wind up with a turbo soon 8)
-C
Penetration Specialist
I agree with doublins...the plp kit and its numbers were quite disappointing. :-?
I think your subject line should read: TBKO S/C vs SRT Stage 2
The SRT Stage 2 is at least 30+ more hp than the S/C. Different ball park in my book.
The PLP (higher powered) Vortech has even less rwhp output than the TBKO S/C.
Just my 2 cents :)
Just my 2 cents :)
^^ agreed....the plp kit just didn't put up the numbers i thought it would. :-?
rather than humming on a tuners jock here and saying which one is better - how about comparing generic upgradability between the two?
Youll be able to squeeze better numbers out of a turbo down the road when you feel like upgrading and feel like spending money. Throw on full 3" exhaust and you get more HP - put on a headgasket and fuel upgrades down the road and turn up the boost and you get more HP. etc. etc.
with the s/c - your upgrades kind of end with the pulley and header.
A turbo'ed car does not behave in the same manor as a S/C'ed car. It's not all about the best bang for the buck folks.
It is about how much you want to spend ($), what max rwhp you eventually want, and what kind of drivability you are willing to give up.
uhh, the PLP vortech is $500 cheaper than the TBKO, and it made 280rwhp on the manual. The TBKO is $6000 and made 275rwhp on an auto. The plp is going to be upgradeable with bigger pullies, etc... as well as the TBKO. I don't see too much of a difference. I would rather go with PLP because they are near me and I could get it installed through CArson Toyota. I think they are somewhat equal in comparison. I don't really see hoe most people think the PLP is not wowth it? :-?
<DegoIS>
Throw in the following TBKO positives...
- No need to move the ABS.
- No need to tap into your oil pan.
- No need to cut a hole in your frame to route the piping.
- More power (I will be the 1st manual w/TBKO's S/C...so I am hoping to see near 290-300).
Is that worth an added $500? :D
On another note...
Vortech makes a high quality product and PLP has excellent customer service. That's a good mix. If PLP is closer to you and you do not mind overlooking the above mentioned, then that might be the way your should go.
Just following this thread and had a comment with respect to the initial topic regarding Intercoolers. I have known many people who have S/C'd their cars (all types) and not one has installed an intercooler, so I'm not sure what your mechanic was talking about. I am sure it's possible, but obviously not a necessity.
My opinion - being a "newbie" on .net is that depending on the type of HP you want and driveability - you can only decide what is better for your own application based on personal preference. From what I have seen, if you are looking for larger gains, it seems as though it's a no brainer - go for the turbo setup. You can easily change turbo's, increase fuel, increase boost (with a headgasket change)...as well as other things.
The beauty of the S/C is that there is virtually no turbo lag -you have power and torque pretty much all the time. They are virtually maintenance free and for more gains, you can easily change the pulley size to increase/decrease boost. But I think you are a bit more limited to the overall amount of power that you are able to attain with an S/C vs. a Turbo.
That's my $0.02
Do a search and see what others are saying about power, reliability, etc. Then make your decision based on what matters to you.
redline814 said:
<DegoIS>
-Actually, you dont' need to move your ABS for the turbo-
-You will need to cut a hole in your engine bay for most FMICs, does the tbko have a FMIC? I thought it did?
-Tapping your oil pan is EASY, and if you remove the kit, you simply screw a plug fitting in place of the original fitting, or just replace the inexpensive sheet metal piece that is your lower oil pan.
-OH-- I got to the "more power" part, and realized you were comparing to plp's s/c. This whole time I thought you were comparing it to the turbo kit. My bad. 8) You need to move your ABS for the plp kit? What a rip!
-C
There is virtually no lag with my turbo setup- so long as your engine is at an rpm where you can produce boost (~3500rpm+), you boost almost instantaneously-
Also, as far as having torque "all the time" with a s/c- Turbos produce MUCH more midrange torque than s/c, because they are at full boost as early as the exhaust gas flow will allow- Superchargers produce boost as a factor of engine rpm, so they aren't at full boost until redline, which is why if you compare the dyno graphs of a turbo and supercharger running the same peak boost, the turbo will produce a much "wider" horsepower curve, with much more area under the curve.
With my electronic boost controller- I can simply dial up/down boost depending on how I'm feeling- if I want to save gas, I drive around on less boost daily. For days when I'm feeling like I want some power, I simply press a button and turn a knob from the comfort of my driver's seat, and voila! If I don't have all the money in the world now, I buy a stage 1- I get 292rwhp. When i have another $1,000 to throw at it, I could upgrade to a stage 2, with an intercooler and more boost- then, if I feel like it, I could upgrade the headgasket, then maybe throw in a return fuel sysrem and fuel pressure regulator. later on, a bigger turbo if I want. You can do things piecemeal- turbos are very easily upgradeable.
Basically, all else equal, if you take a supercharged car and a turbo car running the same boost, both properly tuned, same tranny, same driver- the turbo car will beat the supercharged car hands down each and every time.
Just my $.02. Remember, I am biased :p
-Chris
In response: you just said exactly what I said about turbo lag. Of course you will have no lag at 3,000+ rpm, that's when a turbo is designed to produce boost. The lag comes from 1000-3000+ when the turbo is beginning to spool, therefore, taking time to boost the car = lag.
Trust me...it is obvious to me that turbo charging is the way to go on this car! When and if I move to a big upgrade - there is no doubt that a turbo will be under my hood. I've had three Supra TT's and I love turbo charged cars..no doubt. I've had one SC'd car and that was a 30V 2.8L V6 Audi A4 Quattro. Trqe out of the box - quicker than the 1.8T that I had prior to it too. Just an all out fun car. But from what I've seen on this .NET, 450rwhp in my car sounds like an all out blast!
I lean towards the turbo...I was just informing him of the turbo lag issues that may arise...especially if you use a larger turbo setup. Which is how it is with all turbo charged cars...
lex_is_300 said:
Sorry, not trying to jack the thread.
Doublins - did you make it to the track this weekend?
Hey man, sorry I missed this post before-
Yes, went friday- best was a 13.4 out of 5 runs... Yikes I need to learn how to friggin drive! With 2 weeks of practice I will be doing much better- the car is a totally different animal now and driving her at the track is COMPLETELY different from when she was n/a.
Hopefully I'll be in the 12s with some practice.
-C
1 - 20 of 36 Posts
