1 - 20 of 22 Posts
Mapquest says that Beltsville, Md is 9 hrs. and 5 mins. away from Montreal. I say you can do it in under 8! Mapquest always overestimates!!
I hope to God you're joking.
If you're not, we want pictures of your kit after you perform the coveted beltsville modification to your auto tranny.
Do I get a dot for this?
Podiatrist
LOWLIFE514 said:
ANY BODY INSTALLED THE STAGE 2 KIT
YES
LOWLIFE514 said:
WOULD NEED SOME ADVICED
ABOUT WHAT??????
LOWLIFE514 said:
I JUST ORDERED THE SRT KIT + I"M FROM MONTREAL NOBODY KNOWS ABOUT TURBOCHARGING A IS300
PLEASE HELP
ABOUT WHAT????
YOU CAN TRY ASKING A QUESTION IN NORMAL PRINT.
I think someone will answer if you ask like a normal person.
This doesn't seem like an emergency.
Podiatrist
What? Only 4 million?
You could try to pm the member superchargedIS200. He did a well documented GTE engine swap and my guess is he would be a good source for a IS tuner up there. I believe he is from Montreal also, if not then he is in Ontario (Toronto area). Hope this helps.
1 - 20 of 22 Posts
